Just thought of this today while searching on amazon but some open back headphones would be nice. I don’t think they make a pair like this yet and if they do someone please let me know since I’ve been looking for a decent pair that won’t break the bank.
Inspired by:
and
What about an Anker power suitcase? Here are some specs to start:
Anker PowerCase PD 20-26800
20" roller carry-on
26800 mAh battery built-in
2 USB-A IQ/QC something
1 USB-C PD delivering 45W
Or work with NINETYGO to get the PowerCore+ 26800 PD 45W embedded into it??
6".
All my gadgets are USBC and I have two USBC Powercore.
I just handed Amazon Basics £10 for two cables.
I’m currently using the Type A to C 6" from “Cable Creation” with my Powercore 10000 PD Slim. The cable recently began to fail, I have to move it a few times to work. I’m out biking for a few days and recharge the 10000 PD Slim overnight
That would be pretty cool!
Dual USB-C PD (PowerIQ 3.0) output Powercore. Both me and my wife have newer iPhones which support fast charging via USB-C PD so a battery with 2 USB-C PD outputs (at least 18W each) would be great.
I’ve got a few PowerPort III Duos (36W 2-Port PowerIQ 3.0) for the house and 2 PowerDrive III Duos (again 36W 2-Port PowerIQ 3.0) for the cars so a better equivalent which save us having to worry about having 2 types of cables.
That sound like a good idea but I think they would overheat, I’m obviously no engineer, just my guess lol
With all of the awesomeness that @professor has been sharing by means of his bike tours… I would like to see anker look to develop a
waterproof bike dynamo hub with USB out…
would be able to use in a pinch if other power sources were depleted…
Trick would be to be able to have it such that it could deliver 5v 2a (maybe backwards… )
TS1
I already have this. I use a SON hub and a B&M Luxos U. The hub creates max 6W. If you ride with lights off then it’s all available for USB but if lights on only get USB power at higher speeds. I can usually finish the day with a charged phone.
So I’d take your idea and tweak it. If Anker made a bike light which took the hub output , 6V AC I think, and generated light but any unused excess power charged an internal cell and it had USB output then the light can be recharged and be a power bank.
Would love to see weatherproof outdoor motion sensor for eufy cameras. Have zones that need early detection to start cameras sooner. Recording delay misses people walking through.
Just adding my 2 cents that a water leak sensor would be a great addition.
I love their truly wireless earbuds, but I would like if they made a pair that supports multipoint or multiple devices. I believe Jabra’s truly wireless earbuds are the only other ones, but they run on slave/master mode.
Since USB-C is mainstream now, could we get an upgrade on the PowerStrip Pad?
Looks like the above, but let’s call it PowerStrip Pad 2:
2 AC Outlets
3 USB-C PD (up to 60W on one port)
2 USB-A (12W each)
Basically add 2 USB-C PD ports the existing power strip, then increase the USB-C PD to 60W MAX on at least one port. If all 5 ports are used, maybe around 100W combined? Start at $59.99, and super special sale (Black Friday, Prime Day, etc.) for $39.99.
While we’re at it, could we get a PowerCore 22000C?
No Micro-USB.
No USB-A.
Just 2 USB-C PD.
Maybe 45W from each port?
Sounds good, but I counter suggest with 65W from one port and if you use both ports it intelligently senses each connected device needs and shares 65W out. Say you connected a flat iphone and a flat MPB then it does 18W+45W.
That would be great with it intelligently sensing that would be so nice
Not a product but an app! A user interface for a mobile device is much needed in my opinion.
**Astria Coaxial Acoustic Architecture Headphones. A headphone version of the Liberty 2 pro and you can throw ANC and transparency in there as well.
Powerhouse II 600??
An electric generator
