Hi my 16gb sandisk industrial kept coming up with errors in app, removed, reinserted, rebooted, still the same
I removed it and formatted to fat32 which failed twice then put it back in the homebase which now sees it as 16gb and asks to format but then sits there saying preparing to format
Guess the card has died
Will the homebase support 256gb?
Does it fill then overwrite or do files expire after a period of time?
What write speed is required for 4 cams?
The 256gb cards I’ve been getting I’ve tested & get 68mb/s write & 90mb/s read using laptop internal reader (cf-20)
