Hi. My Liberty+ was working perfectly until recently. The charging case can no longer provide multiple changes. The most I could get is perhaps 2 or 3 before I needed to recharge the case again. I did notice however that the right earbud seems to be always charging when inside the case. After putting both buds back to the case, after a few hours I can see the light on the left bud went off, but the right bud is always on. I suspect it’s always charging thus sucking all the juice from the case.
I’ve turned off Bluetooth, reset the buds, and cleaned the connectors but to no avail. Are there other tricks I can try? Thanks in advance.
