I can’t get to the LED’s to turn pink. Followed instructions to the LETTER. What am I doing wrong?
Zolo liberty earbud problem
I’m having the same issue, the LEDs don’t turn pink. Were you able to solve this?
Same problem. Tried multiple devices with all steps, multiple times. Frustrating.
I tried everything above at least a dozen times. Still no working left earbud.
My fix:
Clean the contacts first! I noticed my center contact on the left earbud looked a little oxidized. Q-tip with alcohol, then clean all contacts, both earbuds and the case, then restarted the reset procedure. Now the left earbud works! This may be just a coincidence, but it worked for me. I hope it helps someone else.
Great you got that fixed.
Of course clean contacts are important!
I lost my right ear bud. Is it possible to use and pair just the left. I’ve tried multiple times only to fail. Can you help?
This is a real question for the support.
You should contact it.
