#UseAnkerInstead! – Powerline ll Lightning Cable (The world’s most durable cable) 6ft
Fed up of stock chargers breaking only months after first use? Fed up of the shortness of length of stock chargers? Well keep your worries aside as the Powerline lightning cable is the best! And better than the rest!
Let’s get straight to the point: For me I had sleepless nights and endless days of worries. I was too concerned about my cable and how I feared it may cause or start a fire. Here are pictures of dangerous Apple cables!
I have only had these cables each for a few months and wires were exposed! This is a very big danger which can potentially cause fires to break out .
Firstly, not only do these chargers have safety risks but they are also expensive. That’s when I thought I should #UseAnkerInstead and it worked out amazing here’s why …
My life saver😍 – Anker Powerine ll Lightning Cable
It’s been nearly a year now using this charger and it’s perfect! . Let me tell you why:
Build quality:
I have had this cable for a while now using it everyday to charge my phone and tablet. It works great. It has a bulletproof fibre which means that it is long lasting and feels very good in hand. The cable can also with stand a-lot of bends.
The cable also has ergonomic feel as it’s easy to plug in and out and the strength supports over 80kg in weight according to anker. Moreover the cable is also MFI certified by Apple so it does work very well with my devices.
Price:
The price of the anker cable is much more cheaper as I paid £8 for it a year ago compared to an Apple cable for £25 which I think that Apple is ripping people of for their low quality products. Therefore, that’s why you should #UseAnkerInstead.
Overall:
I do believe that my anker cable is amazing. The build quality, the price, the safety features all make up for this cable. For the price this is a BARGAIN! Not to forget the wonderful service anker provides truly makes this product and company amazing.
Now that is why you should #UseAnkerInstead!
Thanks for watching!
