Soundcore Flare Plus
Is there a soundcore flare plus in the works? What would it have that the regular flare would not have?
As far I know they will add a power bank function.
Absolutely the Flare + is due out next month with a 99$ price tag
Higher wattage, larger battery, USB port to charge other devices from and wider/taller
From their press release, it will add two tweeters to the two drivers and passive radiators, have 20 hour battery life and can charge your other devices. I’m looking forward to this!
An all-in-one device
@Ankerofficial…when are you releasing the Flare +? Can’t wait to get my hands on one!
Street date has been touted as Aug / Sept 2018 but these things can change…which have been demonstrated on a few past products…should be this year though :slight_smile:
I will be launched in the end of August! We will do a big campaign at that time.:grin:
Soundcore Flare+ offers 20 hours of playtime vs 12 with the Flare. In addition, Flare+ reportedly packs in NFC, a built-in subwoofer, as well as a USB port for charging other devices. Driver is 25W up from 6W * 2. We’ll be able to ā€œconfirmā€ these specs once the device passes through the FCC, which should be soon.
Do you know if the flare and the Flare+ will be able to sync together or will they be considered separate devices?
I’m going to guess they will be separate do to the update speaker system.
I will hold off on getting a second flare then and do 2 Flare+…can’t wait!
Flare+ is now supported by the Soundcore app:
Any update on release or specs?
Yes, the device has passed through the FCC and you can find the latest rundown here. Also now know of Soundcore Flare S+. Details should be unveiled at the end of the month.
yeah now only a built in flashlight is missing and it will be the ultimative transformeršŸ˜…
I think the Flare form factor is a winner. In my opinion it produces a much more balanced and well distributed sound than the rectangle speakers, the 360degree sound is awesome! I’ll be getting more than just my standard Flare if they keep this up!
Shut up and take my money! I want to buy it and test it now! :heart_eyes:
Looks very promising. Is it one tweeter or 2? I couldn’t tell
I agree! Loving my Flare and looking forward to both the Flare+ and Flare S+!
I think it’s two. There are some additional pictures here.
There’s also a new user’s manual. Looks like you can activate a voice assistant too.
And the eighth note/d from the logo is now carved into the silicone mat on the bottom of the device.
