Today i will review the PowerPort Pd 1 and maybe I’ll get you to switch from your stock charger and make you #USEANKERINSTEAD!
The PowerPort PD 1 is a simple, yet reliable and useful charger that delivers 18w. If all you need to charge is your phone and some wireless earbuds or small speakers or anything that uses an USB C charger and doesnt exceed 18w then, this charger is for you.
The charger comes in a gray color, has foldable prongs and features a circle in the middle which lights up letting you know the plug-in has power.
Its 18w means it delivers enough power to fast charge a samsung phone (tested this with a S9+ and S10+) and should charge your iPhone at a faster rate than using the stock iPhone charger which delivers 5w.
And while the newer Atom PD 1 delivers 30w, that charger is $30 vs $20 which is the cost of the PowerPort PD 1. So in theory, this could the middle ground or a powerful enough charger for those who dont need a lot of power for their devices.
So do yourself a favor and get a PowerPort PD 1 and #USEANKERINSTEAD!
