Here we have Ankers magnetic car mount
as always you get the lovely white and blue box and the standard happy/unhappy card and instructions. This particular mount is magnetic so there is a base, which is a stand of sort to hold the magnetic Ball, a top peice that can be moved around anywhere on the ball to suite the best angle for you, there us also 2 magnetic plates that you can either insert between your phone and case or use peel off the tape and mount it to your phone/case…one for you and one for your significant other, or save it as a spareOne thing you will find when unboxing it, is just how heavy the magnetic Ball and base is, even the top piece and metal plates. This screams high quality and there is a reason for it. When installed you don’t want your phone falling off when going over bumps, but with this mount you will not have that. Here you can see just how much each piece weighs in ounces…
As you can see this is a very durable and robust magnetic mount that when installed will possibly be your last mount ever needed…this however is my second mount as I have one in my car and this is going in my wifes.
I will say the included 3m tape that’s attached to the base sticks very well to textured surfaces and I have not had any issues with it on the dash of my Saab 9-5. I have the magnetic plate attached between my phone and the case and even still the magnetic mount holds strong. I have tried with a much thicker plastic case and it held but I never got to test long term as that case was too bulky for me. But for those who like slim cases or even otterboxes, this will work when placed between the outter plastic shell and the rubber part of the case.
All in all I am very happy with this and would recommend it to others. One last thing, I have not had any issues with the magnet being so strong and issues with wifi/bluetooth/ or even GPS. So rest assured this is top notch
