I need help finding a 7 port usb to be able to charge a MacBook Pro, iPhone XR, keyboard and mouse. Any help from the techs with experience. I have the 4 port usb and have run out of room. I now have a mouse pad that needs to be added to the mix. The mouse pad charges the iPhone XR.
Anker USB 3.0 7-Port Portable Aluminum Hub
I won’t be too much help but there are 2 7-port hubs on sale on amazon.com that you might want to look at. It’s easier to see what the differences are but if you’re still confused, just ask and you will receive an answer. This is the link to the thread with the deals
Hope it helps
The problem here is getting enough wattage to power the MacBook…
Wait can you tell me how though?
Lol, I don’t know if anker makes one… others would know better though
