Hi everyone, is there a possibility to see the battery status of the Zolo liberty plus?
I have an android phone.
Thank you guys
Thank you guys
Currently the only way to see battery status with android is on the Pixel phones. It was part of the zolo app but that feature had been removed
Ah, didn’t know the Pixels had this feature. Do you know when it was added? Oreo? Should be rolling out to other Androids soon then once the software updates.
I see :/. But thank you for the quick response.
I’m not sure when it was added, I just know it has the capability as others have posted about it
Definitely thats one of the features needed on the zolo life app or a brand new app like the soundcore with more features or even add the liberty + to the soundcore app compatibility devices either way would be great
