Zolo Anker Liberty W10 Sound Profiles
So I try to use the Liberties for Gaming on my PC and I want it to play Audio from a game and from Discord.
Altough it seems it uses another sound profile when using voice which is named “Zolo Liberty Hands-Free AG Audio”. Whenever this is enabled I can’t play Game Audio anymore.
If I disable this profile I don’t hear discord voices anymore, in addition this profile gives me pretty bad audio quality.
Is there a way I can use the Liberties to have Discord Voices on the standard audio profile and still use Hands-Free Audio as input?
Captura%20de%20pantalla%20(3)
I have the same problem with Zolo Liberty+ (the first option which is ‘headphones with microphone’ won’t work properly).
