xperiaxz1 compatible with PowerCore + 26800mAh?
I wonder if xperia xz1 is compatible with PowerCore + 26800mAh?
Thank you
Hi @leonardoskx , yes the PowerCore+ 26800 is compatible with the Xperia xZ1 for charging, including fast charge with the dedicated QC3 port.
There is also the PowerCore Speed 10000 and PowerCore+ 10050, which would be suitable to recharge your phone up to 3 times on a single charge (fast charge via QC3). Both units are more compact and are normally in the $35-36 range, if you mainly after charge for your phone only.
Thanks for the info!!!
