Xiaomi's 100 W charger - Anker, Your Move!
Anker just released the Atom charger with GaN technology which supports 30W. When will we see a 100W charger to compete?
Xiaomi’s 100W charger fills a 4,000mAh battery in 17 minutes - The Verge Article
The people want it, Anker! Your move!
Yes anker. Go for it… if you don’t, you will be behind, many other brands will Begin to release 100w chargers…
That was my first thought.
Can we see a 100W, 5,000mah GaN Fusion?
100W GaN based charger may take sometime, but Anker already has Launched PowerPort Atom PD 4 100W USB-C Charger
You’re right, but isn’t that spread over the two USB-C and two USB-A ports?
yes, below are details from @joshuad11 on Anker Forum
PowerPort Atom PD 4
Features & details
Super Power - Provides an enormous 100W of charging power - enough to charge 2 USB-C laptops and 2 smartphones at the same time. USB-C Output: 5V = 3A / 9V = 3A / 20V = 5A. USB-A Output 5V = 2.4A max per port.
High-Speed Charging - Save up to 1 hour of charging time with USB-C Power Delivery and Anker’s world-famous PowerIQ technology for USB-A.
Universal Compatibility - Optimized for flawless performance with USB-A and USB-C phones, tablets, laptops, and more, including the 15-inch MacBook Pro, 2018 MacBook Air, and 13-inch Dell XPS.
Intelligent Power Allocation - Provides up to 100W of charging power while one device is connected to a USB-C port, or distributes output to up to 4 connected devices.
What You Get - PowerPort Atom PD 4 wall charger, adhesive strip, welcome guide, our worry-free 18-month warranty, and friendly customer service.
Pricing and Availability: Anker’s PowerPort Atom PD 4 is available to order right now via Amazon US for a cost of $99.99, and should begin shipping imminently. However, stock is very limited at the moment.
https://community.anker.com/t/breaking-several-exciting-new-releases/
Yeah I saw all that, I’m trying to make sense of what that all means.
So assuming the Max Output on a USB C is 9v at 3A, then you get 27W max out of one port? So still ways to go…
Anker mentions [quote=“cshenoy, post:6, topic:67371”]
[/quote]
Good call! Well then, case closed!
Although I think it would be beneficial to create a smaller footprint and not the PowerPort design which can be a bit clunky and not as travel friendly.
That is on the wishlist :slight_smile: hopefully GaN design
Your mistaking a proprietary charger for a regular charger. Xiaomi’s charger while great, will most likely only power and work to charge their phones and not other devices. This most likely goes against the USB-C standard in order to achieve this high rate of charge, we would have to wait for it’s release and spec sheet to know more about it. But personally I doubt it will be beneficial for other device uses.
While yes we want and should see higher powered chargers, this one most likely isn’t what we are looking for
From the demo video it looks like the phone is accepting around 72 W power on average.
If it’s a single li-ion battery of 4000 mAh capacity it will be 3.8V x 4 Ah = 15.2 Wh capacity
In order to charge this in 17 min (or 0.2833 hr) with 72 W power the battery must be taking in 53.65 Watt. This means the current input is 53.65W/4.35V = 12.33 Amps (that’s IMPOSSIBLE)
Most likely they have splitted the battery in 4cells so each cell is at 4.35V (total close to 18V) with each battery cell getting about 1 A (total of 3.5-4A) charging current. That’s LOGICAL and safe to do…
I’m sure Anker can compete with that!
I am busy this week traveling (with a lot of Anker tech) but
