Goodday,
Since today my video doorbell is acting up, the wifi signal at the door is perfect (200+mbs) the distance from the homebase to the doorbell is No more then 50 cm, it works fine when I have the doorbell in the living room, it worked fine the moment i installed it (until This morning)
Ik check for updates… none, reset, restart, reconnect… All the same.
Any advice?
