Wired doorbell keeps going offline
My Eufy wired doorbell is acting up, it keeps going offline within a few hours of it being reset. The power from the transformer is fine and so is the WiFi connection. Any suggestions on what may be causing this issue?
Contact support, based purely on your words that sounds like a dud unit to me…
https://www.eufylife.com/contact
Thanks, that will be the last resort before having to accept I’ve got a glorified doorbell!
Ok but going offline so often has high DUD hints.
Did you go through a full reset? Look for hard reset.
