I’m looking to buy the 60W power adaptor and I was wondering if it will power the Switch in TV mode without bricking the console.
Does anyone have experience with this?
i think if you use the 3 bottom ports then yes, the 2 on top re much stronger. i bet the ports re safety and dont destroy the devices
I’m talking about the USB-C PD charger with only a single slot
I use it, and it charges safely. It nagotiates the same way it does OEM charger does in hand-held mode. Don’t use it on the dock though.
