Im very confused with all the cables there are. Can anyone point me to the best product that can replace the stock usbc-usbc cable that came with my macbook pro? Thanks!
Which usbc cable is the best for a 13* macbook pro?
Hi @Alexander12 , there are quite a number of cables that Anker offer so it can get confusing. If your after a replacement for the straight USB-C to USB-C for charging your MacBook etc I would recommend the following, plus its backed by a lifetime warranty ;
The stock one from Apple is great
