Which earbuds?
I am considering buying a pair of anker earbuds but not sure which one to buy. Mainly because I can’t really tell much of a difference between each of there earbuds. The only difference I found between the surge, slim, and curve, is the battery life and style vary I little. They are all the same price and are water resistant. I would be using them for doing outdoor landscaping and would definitly want durable ones.
Which one do you guys recommend for this?
Thanks in advance!
If you do a search in here you will find many reviews from various users which can give you an idea if what each offer. Then choose which you prefer, me personally I like that spirit X as they are water and sweatproof and sound good. Or for total wireless go with the liberty air.
Are you considering true wireless? Liberty Air are a really good AirPods replacement, but it has its cons versus a good price.
I will suggest soundcore Curve (wireless) and Zolo Liberty (true wireless)
Curve has best audio performance and codec support and has highest battery life in its category. Zolo liberty has stunning audio quality. With its charging case you can get 24h of playtime (5 h each charge).
the Zolo Liberty + is a good choice
I have the Soundbuds Flow and the Liberty Air but definitely prefer the Air due to not having any wires.
i have the liberty+ and lites, and they’re great
