Hello, recently I just bought a second hand router, and it’s missing an USB-C adapter which rated at 12v and 1.2a.
At first I try it using my regular phone charging cable and my charger which has 12v and 1.5a output with no luck, the thing just won’t boot up, and then during my frustation I found out that my cable is only rated for 5v usage 9v only I try to do some research about type of cable for charger and I found out most company didn’t rate their usb cable voltage at all. Even anker powerline didn’t have any voltage rate.
So I need help to decide which charger and cable should I use to get the 12v output to my router. Any help will be appreciated.
