Which Anker powerbank would you recommend?
Hi, I’m looking for a new power bank. Do you have any recommendations?
Depends what devices you need to charge. If you just want a good one for a phone I would recommend a 10,000 mAh or 13,000 mAh because of the size but a 20,000 if you have a tablet or something with a bigger battery.
This is a very vague question, anyone could recommend any powerbank of any size and use. But to really answer your question we need to know what you will be charging, does it have quick charge? Are you looking for single or multiple charges from your battery pack. Another question to ask is do you care about portability and weight, or the number of charges matter the most?
Answer these questions and we can better help you
I would recomend the powercore 10000 II because it can charge any phone three and more times. And can also last months without draining battery when you are not using it. I personally think it is the perfect option if you are only going to charge your phone a lot and cannot access a outlet often. Also look at the anker slim battery bank, because it is very nice to with its sleek and beautiful design.
Some very good info from the community already but if you are only looking for something small to get you through a day then you might want to consider a small one
[PowerCore 6700] (https://www.amazon.co.uk/Anker-PowerCore-Compact-Portable-Smartphones-Black/dp/B07211V9XG/ref=sr_1_10?ie=UTF8&qid=1516822987&sr=8-10&keywords=Anker+powercore)
[PowerCore 5000] (https://www.amazon.co.uk/Anker-PowerCore-Ultra-Compact-Fast-Charging-Technology-Black/dp/B01CU1EC6Y/ref=sr_1_8?ie=UTF8&qid=1516822987&sr=8-8&keywords=Anker+powercore)
[Newer and decent size for several charges, PowerCore II 10000] (https://www.amazon.co.uk/Anker-PowerCore-Ultra-Compact-10000mAh-Portable/dp/B072MH1434/ref=sr_1_7?ie=UTF8&qid=1516822987&sr=8-7&keywords=Anker+powercore)
Might you please specify your request a little bit.
What kind of item you wish to charge, do you need USB-C?
Are weight and dimensions important for you?
You know, there are many power banks ANKER offers.
I’m sure we can tell you the best solution.
Depends on the use! Are all great! Anker’s power banks are the best on the market :wink:
It really does depend on your uses. If you will be charging a laptop with it, I’d go with a PowerCore+ 26800 with USB-C PD. If you were charging an iPhone or iPad, I’d go with PowerCore II with Power IQ 2.0, and if you were charging Android devices with QC 3.0, I’d go with the PowerCore+ variants that support QC 3.0.
You won’t go wrong with any of them, just pick the one that fits your uses best!
As others suggested we need to know about your needs. If you have several devices I wouldn’t go any lower than 10,000 mAh and any of the Anker Power banks with that rating or higher would be great.
If you need a small one to fit in your pocket I would go with a Powercore 5000 or the Powercore 3350.
I have the Powercore 5000 and I can do a 20% to 100% charge on my LG G4 at least twice. Its light weight and built to last.
Looks like you’ve already got a lot of help here. Now you just need to tell us more information ! :grin:
