I bought a PowerCore Elite 20000 3 days ago now im thinking i should have bought the PowerCore 26800 instead?
Are they almost the same except the mAh?
Whats the big difference between them?
/Jakelol
/Jakelol
6800 and weight.
Plus, you remove “approx” a fifth for technical reasons. So by getting the larger varient, you actually get 20,000 of useable powerbank.
Battery packs used generally are the same mah, but obvs in sets to make the size given. Soore than likely the mah would be the same regardless of size/power… I think!
Is the 26800 using 18600 batteries and what are the Elite using?
Do t know that bit
The power core elite uses lithium polymer batteries, besides capacity and features it all depends which 26800 batterypack your talking about in comparison.
You can’t go wrong with any of them, it comes down to preference and features that benefit you and your charging needs
Its these two im talking about.
What i can tell they use different batteries and one has 6800 more mAh and they both have the exact same types of ports.
Is there any difference in the batteries? What i can tell the 26800 use 18600 lithium ion and you say the Elite use lithium polymer?
