For the love of god can you plz make a new screen protector for iPhone 8s (at least). The ones you make are OK, but they need to be full wrap around or something new, plz. Thank you very much for reading my rant!
Would love the robo vac and zolo libertysā¦
Anker - what are the chances of developing a ādockless dockā for the Nintendo Switch? Aka a dongle like your existing USB C adapters but one speccāed to work with the Switch? It would need 1x USB C PD in, 1x HDMI out, and a usb port or two.
You have enough relationship to do the co-branded batteries⦠letās pray for a dongle! Would be a huge seller as thereās a massive untapped market for a licensed travel solution vs. carrying the big dock around.
EDIT
Not certified by Nintendo but Anker already has a hub with type c input/output USBtype-A ports and HDMI output.
Thereās also a cheaper $70 option but that is limited to 60 watts instead of 100 but should be more than sufficient for the Nintendo switch.
How about a eufy āLED strip light controllerā that is controlled with the Eufy home app or smart home Alexa/Google and a Bluetooth remote.
I like the sounds of that! One that would be a cheaper alternative to the Philips Hue light strips.
Iād happily pay $30-35 for a good LED light strip controller that is highly customizable and has a memory function to remember the controllers last light setting.
I donāt think it outputs HDMI video correctly for switch. Does it? Iād love to be proven wrong.
@AnkerOfficial
it would be awesome if anker made more companyās for smartphones etc⦠thanks!
waiting for more awesome products!!
Iād like to see scented LED colorful lights!!!
Also, an HDTV antenna that is better than most on the market.
Iām not sure if it would output video perfectly but I know you would get video⦠After doing a little research the original dock is the only dock that I would recommend all other ones do not manage power properly and could
severely damage your switch.
A small compact 20000 mah powerbank;)
The 20000mah power banks are pretty much as small as possible right now but will shrink as battery and charging technology progresses.
In germany there are many bicycle riders. So a rechargeable (USB) light white for front and red for back would be nice.
I want anker to make something similar to Alexa
Check out the eufy genie (Alexa) and zolo moho (Google home)
Honestly a 6 inch USB to USB C cable would be nice. It would be nice to use with my Anker power banks.
And the Flare S+ (works with Alexa), which originally was said to launch for the 2018 holiday season, so hopefully is coming soon!
