I currently have 2 battery packs the 26800mah and the 16500mah. I usually recharge them when they hit about half power, I have heard that running them to empty can be stressful on these batteries.
What is the best way to recharge Anker lithium ion products?
You can recharge them at any time (half full, 3/4 full, etc) as there is no “memory effect” with lithium ion batteries. You are correct that complete discharges can negatively affect the battery, but every once-in-awhile is OK.
So, basically, charge it whenever you get a chance and the batteries should last you a long time.
We always recharge the battery when is either dead or when one light is left. It take some time for full recharge so better leave it overnight.
