What is the best power-bank to buy from Anker?
I think the 13,000 is a great powerbank.
I think there’s an upgraded version too.
I could use some help in choosing a new Anker power bank. I have an iPad Air 2 and iPhone 7 Plus that I would like to charge at the same time. I will be taking these devices with me on a flight to Prague this summer. So basically I need a power bank with two ports and fast charging, but I prefer something not too large or heavy. Would what you experts recommend? Thank you!
Best deal is the fusion 5000. It’s not fast charging, but it does charge two at once and functions as a wall plug for only $26:
https://www.amazon.com/Anker-PowerCore-Portable-Charger-Foldable/dp/B01K702S66/ref=sr_1_3?keywords=anker+fusion+5000&qid=1556298704&s=electronics&sr=1-3
Best fast charge is probably this one. With 20000 mAh (4x as much as the fusion) you can get lots of charges off this thing. It’s also got QC3.0 so it will charge your things as quickly as possible:
Thank you. So you think 5000 mAh is enough power? The 20000 might be overkill and larger. Perhaps a 10000 might be a good compromise?
Well, 5000 mAh isn’t going to fully charge both devices from 0% - with both of those devices combined you have 9300 mAh of battery. So fully charging both would need something like this:
https://www.amazon.com/dp/B00Z9QVE4Q/ref=sr_1_10?camp=217145&creative=399373&creativeASIN=B00Z9QVE4Q&ie=UTF8&linkCode=as2&sr=1-10&tag=ianker-20
That also have a smaller form factor as well as over 3000 mAh to spare. That’s probably what you’re looking for.
Oh wait, this is the one you want if you have a usb C adapter:
Sorry for my ignorance, but what is a USB-C adapter and would I need one for my iPad Air 2 or iPhone 7 Plus? I don’t currently have a USB-C to lightening cable, but just a USB cable that I use to charge these devices.
That power bank charges really fast with a usb-c cable, but if you arent; using any usb c products then probably the other one is best for you:
The only reason the OP was using a USB-C adapter, was because he was using a USB-C wall charger.
Your set-up doesn’t need one, so don’t worry about it.
How about this one? It has more power than the 13000 but it’s still small. Can it charge both devices at the same time? That is primary concern. If not, then I could also go with the PowerCore II Slim 10000.
https://www.amazon.com/Anker-PowerCore-Ultra-Portable-VoltageBoost-Technology/dp/B07HBWF1K8
Does that imply you’re in UK? If so then the Fusion ideas won’t apply as it’s USA only.
This is the best bang for your money…
Anker PowerCore 15600 mAh Super High Capacity Battery Pack Power Bank with Most Powerful 4.8 A Output and PowerIQ Technology for Smartphones - Black https://www.amazon.co.uk/dp/B00VJQLKNK/ref=cm_sw_r_other_apa_i_wX3WCb9ER0AM8
I would recommend the powercore 13000. I think it would work great for you!
No, I am in the USA.
i would say if your looking for a power bank that can last you all week the power core 20100 and if you want a small one the power core 6700 II small and mighty!
i wish it was in the uk anker should make one for the uk :slight_smile:
