The model number says T8112, I thought I was buying a eufyCam with the Sony Exmor sensor but at the moment I’m confused what I have.
I note that the base unit wanted to connect to the same router as an android smartphone running the eufy app. It then merrily updated its firmware. Since I hadn’t entered the router internet password into it do I assume it used the smartphone connection to the internet to grab the firmware update in someway?
Is there a user manual available somewhere? The box seemed to indicate there is such a thing but it seemed to be missing.
Thanks John
