Hi,
Big fan of Anker products. But lately I’ve had to spend more time than I like helping those to whom I’ve recommended Anker products navigate the website. Making a recommendation for your product can be hard when you end up getting dragged in to each purchase because the manufacturer website is too confusing.
Can you please group products together in a more logical or flexible way? For example you could have the smallest lipstick/tube format chargers together with a drop down to compare specs (dimensions, weight, input/output power, etc.) The current organization by series is meaningless since a series doesn’t have a consistent feature set or design.
And allow users to compare features? Right now you have to browse each series open up the similar products from each series in a tab and manually switch between them to compare. Why can’t the power core mini, power core mini+ and Powercore 5000 very compared? They’re so similar and this would help illustrate the differences more clearly.
