#ILoveTesting
@AnkerOfficial Thanks for giving me this opputunity
Hope to keep testing more of your champion products
Amazon link: https://www.amazon.com/Anker-Adapter-Reader-MacBook-Chromebook/dp/B07H4VQ4BZ
Look:
The Hub is made of solid aluminum which makes it perfect for tossing in your backpack or suitcase. Furthermore, it has a nice polished look and blends in with my Zenbook Flip well.
There is also a white Anker logo on the top to add style,
the appeal of the product screams solid quality
Features:
There’s two usb 3.0 ports and one HDMI as well as a sd card combo port (for both standard and non-standard sd cards).
A bonus white light indicator is located on the side and the hub connects though usb-c
The data transfer speeds are blazing fast as you would expect from inputting and outputting though usb 3. Didn’t have a monitor to test the HDMI though
Cons:
This hub doesn’t support DisplayPort and have a lan port. The cabling gets dirty easily because it’s rubber and also too stiff.
This is a fingerprint magnet so you’ll want to have a cloth and cleaning solution on hand.
The indicator light is hard to see and in the worst spot ever. Should be red instead of white
