We Love Testing - 5-in-1 USB C Hub Review
Doing some work on updated website. Never run out of ports on my new @apple MacBook Pro. Using my Anker 5-in-1 usb c hub. When I first got this MacBook my biggest complaint was that I didn’t have usb c cables for all the devices I own/use and I wasn’t about to go out and buy all new cables. Found this gem and it works amazing!
What’s Connected:
  • 128gb usb thumb drive
  • 400gb microSD in SD adapter
  • usb iPad cable charging iPad as well as connecting to MacBook for secondary monitor
  • hdmi port not being used currently.
Dimensions: hub is 4 x 1.75 so definitely small enough to stick in pocket of laptop bag. The cord length is approx 7 inches which gives you enough space between laptop and other devices.
Pros:
  • Small Size
  • Enough ports for a majority of devices
  • Seemed to have low power draw
  • Solid study construction
Cons:
  • USB cable stopped charging ipad, possibly due to non apple cable.
  • USB-C port on hub would be nice, but that’s included with the 7-in-1 hub.
This is a must have in my bag. Been using for a few days now and have no complaints. #welovetesting @AnkerOfficial useankerinstead
Nice review, but I would have liked more pics. I like the one you have though :+1:
Just so you make sure anker gets this, the proper tag is @AnkerOfficial :wink:
Btw, entering this as a use anker instead entry is clever :joy:
Nice to see the hub in action.
Nice review, may be if you can add some more pics showing the Hub - will help out other users decide if they need to get one!
Nice review @Ryan_Boubelik ,have the 7-in-1 myself and its a lifesaver sometimes :slight_smile: thanks for sharing :thumbsup:
Nice review!
I agree with you
Nice review and photo! You can never post too many pictures of the product in action.
Nice review!
