Wakey Alarm Clock Wireless Charging Trouble
Hey folks, got a new Wakey Alaram clock. When I place my phone on the wireless charger seems to work fine but eventually the blue charging light stops flashing and the phone stops charging. This happens in and out of a case. Just wondering is anyone else has seen this issue? I’m thinking of returning it if it can’t charge properly.
Not the same issue but in my first Wakey the charging coil developed a fault and it would produce a weird buzzing noise while charging.
If its under warranty get an exchange from the retailer as this is often the quickest route to a new unit.
If not, contact support@anker.com and they will offer further advice.
Thanks for the edit @ndalby :+1:t2:
No worries, done it myself in the past…
Seems like you got a faulty unit man
