Volume control with Capsule II remote
It appears that the volume control with the remote from the Capsule II only works pointing to the device, that is, bluetooth is not supported.
Is this expected, is anyone experiencing the same thing?
Thanks
More information please.
What device are you talking about.
That’s as per original and the Mars.
IR (line of sight) only, no BT
Yes, I was talking about the remote of the Capsule II, paired with a Capsule II using bluetooth, in order to adjust the volume I need to be pointing to the device, which really sucks. If the idea of bluetooth connection is to avoid having to point to the device, the fact that for changing the volume I still need to point to it makes the bluetooth kind of useless.
Was thinking the same, I know the Capsule 1 is definitely IR based, so requires line of sight…
