I just bought them. Everything is great and I love them. It works fine with android, but when used with PC, I cannot control it’s volume from computer.
Does anybody face the same problem?
Have you checked this issue by connecting with a cable?
@Varun1 What version of BT is your PC running and is it at the latest driver version (from the BT card manufacturer)?
Yes, may be the “old” and well known WIN10 problem.
Would be an idea to add this issue and the solution to the manual of all speakers.
@ndalby Later I realised it’s the incompatibility with AVCRP Absolute Volume introduced in Window 1803.
Disabling it using registry fixed the issue.
@fhassm Maybe they should fix the compatibility issue instead. I think these speaker support flashing new framework using PC, so it’s very doable, and help a ton of users. I can disable absolute volume, but now I am missing a feature that other brand bluetooth speakers offer.
Was only a suggestion and a suppose of mine.
Sorry I haven’t got a solution, but I don’t use WIN.
All my speakers work fine with LINUX, the volume control
can be made on both sides, though it is a little bit tricky to get bluetooth working properly.
And you forgot to tell us which speaker you are talking about.
