is it possible?
Use soundcore microphone on pc?
Try it…might be possible. if your soundcore is connected via bluetooth and if it has the required bluetooth codecs for microphone it may be used (like bluetooth earphones microphone).
Never tried it, but this could work, depends if you are using the codecs which supports the use of a mic and of course depends on the OS you are using on your PC.
(I suppose WIN)
i cant get it to do anything it shows up in recording devices but cant talk into it
As long as it’s bluetooth and has a microphone it should be possible…
