Has anyone else had problems with the Anker USB-C to Dual HDMI Hub? I am not sure what is wrong, it just seems as if my computer is not even noticing it as a display output, and it is not doing anything but tell me there is a new device connected when I plug it into my laptop.
USB-C to Dual HDMI Hub Adapter
Are you sure your laptop USBC port supports display? Once you’ve checked it actually does then do post 5
I would also suggest trying a different port if you can
I recently purchased an Anker USB - C Hub to allow me to connect two is there something else i need to be doing to get this to work? For what it’s worth i’m also not seeing anything happen when i plug an SD card into the hub.
Device? Research it’s port and it’s capabilities.
