USB C PD Options with 12V?
I’ve got an Anke Powercore Speed PD 20000 and it works in a huge variety of PD modes, including 12V. I recently helped someone with a solution to power something that required 12V and am looking for more options that are USB C that will hit that.
So far most products are not hitting it. Anyone know of a list or have more definitive information on what Anker makes that support 12V? Listings are pretty useless on this topic and devices that do hit 12V do not advertise as such and others that advertise essentially the same output do not support it.
Kind of a niche question and not finding anything.
If the device is not PD then a PD Powercore won’t necesarily work, you’d have to buy a USB driver which presents as a PD, requests 12V then output the delivered 12V.
No there is no definitive list, you’d have to ask support for each product you wanted.
Chances are someone here would own and read off the little label.
