USB-C Hub question/recommendations
I have a 4k USB-C monitor that provides 85W of power to my MacBook pro through the USB-C connection. Do any of the Anker USB-C hubs with PD pass data through the USB power connection? I would like to connect the USB-C connection from the monitor to the power input on the hub and pass video, audio and power all through the USB-C connection. The idea is to connect my laptop to the monitor, ethernet and a couple other devices through the hub and charge the laptop from the monitor.
Will any Anker hubs support this? If so =, any recommendations?
The ones with a “Multi-Function Port” or a Thunderbolt not connecting to the computer will support this. The rest? Not really.
