UK Eufy indoors camera
The camera (non pan-tilt) shows currently unavailable.
I’m happy and sad to see these as i recently bought a pair of cheap cameras.
I can still send my TP Link cameras back, but they have been very stable.
I need to read some reviews i think!
The reviews so far are positive.
The chatter about the outdoor cameras are so consistently negative it’s convinced me to avoid.
Well, not that i wanted to say that out loud but thats my thought.
Perhaps these “dumb” cameras aren’t intelligent enough to be troublesome.
It’s hard to get a true picture of what products are like now days. If you look on Youtube, most videos are sponsored by Eufy. If you look on Amazon there’s people leaving bad reviews because they don’t understand how they work. It’s a mess at the minute.
We’re not Anker staff so don’t hold anything back.
The issue seems to be the Eufy external cameras store data locally and yet need a remote server to access them so bad architecture. These are just simpler so less things to fail, and good image quality.
Yes, so far the indoor cameras are working great. They just released HomeKit upgrade, and it’s a batch release so few regions have noticed it and the other regions, specially in EU have not seen it yet. I understand it will be released by tomorrow (Jul 14th) .
So, the chatter about these cameras mainly is about who has it or doesn’t have it.
Also, there are some limitation when you integrate with HomeKit, so obviously, pros/cons of HomeKit :slight_smile:
Good news @Ice1
On the blurb does it mention the frame rate?
Do you know if it is full TV frame rate, 25/30 FPS or a reduced rate?
I have some 15fps cameras and the motion is not that clear, which is obviously not that great for a security camera.
I have to check for that info… May be @Shenoy or @Fuu_bar knows about it?
@onstar has the non-pan-tilt
But yes the chat in June said 15fps
To my knowledge, they are 15 FPS each
Eufy Indoor Cam 2K Pan & Tilt
  • Dimensions: 75 x 75 x 108mm / 2.95 x 2.95 x 4.25in
  • Weight: 217g / 7.65oz
  • Power: 5v/2A AC. Micro USB power port
  • Pan/Tilt: 360Âş horizontal / 93Âş vertical @ 85Âş per second
  • Resolution: 2K
  • FoV: 125Âş
  • Night Vision
  • H.265 & H.264 encoding
  • 8 x zoom
  • FPS: 15
Eufy Indoor Cam 2K
  • Dimensions: 55 x 55 x 104mm / 2.17 x 2.17 x 4.09in
  • Weight: 98g / 3.46oz
  • Power: 5v/1A AC. Micro USB power port
  • Resolution: 2K
  • FoV: 125Âş
  • Night Vision
  • FPS: 15
Well done @professor I thought id had the conversation but could I find it? :man_facepalming:t2:
I think at 15fps I don’t think it’s worth changing from my current setup.
The thing is, I have not had any issues with my pan and tilt at all when it comes to the frame rate.
Haha beat me to it by a hot second there.
Cheers @Fuu_bar :+1:t2:
I think its weird to have such a low FPS.
I have a (very) cheap action camera that records 25fps in its lowest setting.
Yet in a security product where clarity of picture is surely the most important factor, the rate is lower.
Bear in mind that this is a gif from it because I cant post the full file, but it is smooth normally. (Don’t mind my dirty kitchen and my tired looking self from my kids all day)
That’s reasonable @Fuu_bar thaw for posting that.
Does the camera pan by itself to track your motion? That’s pretty neat if it does.
Yeah it is automatic pan for it.
This is a lot better version
Here a link to theTPLinks I’m running.
Aside from the panning, I think the Eufy has it for quality.
I’d go with reviewed quality above specs, as there’s plenty of other aspects. The level of onboard compression means one fps can deliver more detail than others.
I do lots of media recoding and the delta frames can be larger, so show more changes, for a given fps so the image is better, less jumpy, less blurred, so fps is not the totality of the quality. A weaker processor can compute less delta so make the file size consequentially larger for a given quality or have more pixelated delta. A stronger processor can detect more fine-grained the delta so make them smaller so both small file size and good quality. So a big fat “it depends”
When someone puts a h265 co-pro in a consumer low cost camera, the wow moment will happen, it compresses twice as fast but at a computational cost. So that means either twice the quality for a given file size or half the file size for a given quality.
I can see the weight loss from the low-carbs low-beer on you there Paul.
