I have the Homebase in my Bedroom. At night the LED is very bright. Is there a way to switch the LED off?
Turn off Homebase LED
At this time there is no option! I have sent eufy support the suggestion of this being possible.
As @llewellyn1971 has said, at present there is no option to shut off the light (and I can see some reasoning behind this). The best you could do is try to block the LED with an object or perhap put a bit of electrical tape over the area for the present.
