I bought the Solo s340 and the new Dual Cam floodlight and wanted to trigger them from my Eufy S330’s. It would be really nice if you could use a different camera like the s330 to trigger the s340 to record AND change its preset (if setup already) to a new location. This way you could use the overhang ability to hang it at the corner of your house and it look down 2 sides of your house and swap to the side it needs to look at if triggered by another camera or sensor. Would add alot of things you could do with your cameras.
Trigger presets in Automation
