The Videotimestep ist not showing correctly - although i set the time in „Devices“ to GMT +1, on Video it is showing the GMT time when recording. I rebooted the base but this dod not change
I had the same issue. it took some time to update the time stamp on videos to the settings of timezone selected for homebase. Give it some time, restart again!
What version is your homebase firmware? Should be 1.0.5.9.
Some follow-up:
These two replies are important. The homebase firmware version is most likely the issue. Keep it plugged in and it should be updated by tonight, if not now.
@Franco try to logout of eufy security app and then log back in. This has solved the problem for a few people here in the community.
