Swivel wheel on robovac
Not sure how to remove the swivel wheel on the robovac
Sorry, I’m not a native speaker but if you mean this wheel in front.
Easy:
Try to pull a tape through that wheel by rolling it, and just pull it after.
Easy.
Nothing you might damage this way.
It’s the wheel that gives direction.
This one:
If so it can be pulled out easily the way I told.
