Switch Lite
What do you gamers think of the nintendo switch lite, I personally thinks it better to just stick with the original switch, the functionality is way better.
For most the regular Switch is better. Larger screen, more battery life, and the ability to connect to the TV are worth the extra cost. The Switch Lite is good if the extra $100 is the difference between getting a Switch or not. Or for those who travel a lot. Where TV connections aren’t a concern and size and weight is.
That said, aside from a few Joy-Con requiring games the Lite performs as well as the full size model, mostly using the same internal hardware.
