As a motivationally challenged tech enthusiast, it’s important that I’m utilizing the latest innovations to do as much as possible for me. But what about those of us who rent, yet still want to take advantage of the latest in smart home technology? My landlord might not appreciate it if I try to make a bunch of upgrades (especially considering my construction skills are pretty much nonexistent).
If you want to step into the future without the risk of getting evicted, here are some things you might want to consider!
This little light of mine plugs into any standard bulb socket you have in your house. Once it’s installed, you can use an app (or your voice, with a compatible Alexa device) to set the perfect ambiance. No amateur electrician skills required!
Why just stick with smart-ifying (smart-ening?) the lights in your home? With this smart plug, you can remotely control many of your electronics through the EufyHome app or an Alexa device. An extremely compact build prevents the smart plug from blocking other outlets—giving you the freedom to plug in everything you need (including more smart plugs!).
When it comes to keeping your new electronic goodies safe inside your home, why consider any other option besides the most-funded smart home Kickstarter ever? Unlike most home security systems, eufyCam requires no intrusive installation, and no recurring fees. What’s more, the weatherproof cam’s battery will last 365 days on one charge. That’s reliability you can count on.
Even if you don’t own your home, there are plenty of ways to make your house as smart as possible with eufy!
What about you, fans? How will you upgrade your home life in the remainder of this year? Let us know in the comments, and Power On!
