Spirit X not working on chromebook
bruh MOMENT Soundcore spirit x dont work on a chromebook HELP ME!
It’s probably the BT driver on your chromebook. I would delete it and reinstall it.
If you don’t know how to do this, you should be able to find a tutorial online.
I myself have a old Chromebook and connected bluetooth devices in the past without any issues. Not paired the Spirit X, will try it today.
Meanwhile, you may use the below link to pair it fresh:
https://support.google.com/chromebook/answer/2587653?hl=en
Its not WINDOOFS its CHROME OS a kind of “Andrewiod” :joy:
That doesn’t mean it isn’t the BT driver :joy:
How would you change that BT driver on Chrome?
Chromebook automatically checks for updates from Google Servers each time it turns on and connects to internet. It will download the updates in the background while still connected to internet. This is the way it has been doing till now… there are no are other ways to update any drivers unless you do a crouton (secondary OS) or have a dual boot with Windows (which is not supported, may not even work)
Do let us know if you have any other ways to update the drivers on Chromebook
Chrome : UNIX derivate, same as LINUX.
All drivers are imbedded in the kernel.
If you are really lucky you get an extra one from the manufacturer might be working better than the default one, as far I remember…
100% agree, Chrome-OS is a cut-down, slimmed version of linux, which has its appearance molded around Google Browser Chrome (hope they didnt do this to complicate or confuse users)
Users need to be confused!
Or much better they should know nothing about that what they are doing and using.
If there is no knowledge, there is no confusion only astonishment, assumptions
and a lot of miracles! :wink:
The problem with those proprietary drivers, if there is one, if the manufacturer stops development you might be lost.
again, if you cannot convince, confuse :smiley: this seems to be the idea brands are using nowadays
