Soundcore1,2 - Microphone compatible with Android tablets?
Hi. The reason why I am asking is because I have a Kindle Fire HD10 and it is not compatible with external mics. So when I tried using the Soundcore for Zoom meetings, the speaker was fine, but the Kindle Fire microphone was used and it created echo.
So If I were to get an Android tablet, would it be compatible with the mic on the Anker, or would I have the same problem? Or does it depend on the Tablet manufacturer rather than the operating system?
Thanks for your help.
I have multiple Android and Soundcore and I’ve always found the Soundcore microphone is used.
You sometimes find the used for calls option hasn’t happened and have to select it.
