Hi my sons anker soundcore earphones he bought a couple of months ago have started to crackle and make funny noises randomly. What does he need to do to get these repaired or replaced as I cant find anything on the website
Soundcore wireless earphones
Get them replaced asap
Does the crackle / noise happen when paired to more than one device? Also have you tried a reset of the earphones?
We are sorry to hear your headphones are not working properly. According to the information you described, the issue you are experiencing is very unusual. Please try resetting your earbuds to see if it helps at all.
If the issue still persists, don’t worry, please don’t hesitate to contact us at support@anker.com by detailing your order number and the problem you come across. We will reply you within 24 hours.
