Soundcore Wakey display with Firmware version update 0.6.0
Does anyone know how to change the display with the 24 hour format to not included the sun and moon display? I’ve seen reviews with photos of it just displaying the time without the extra feature. I’ve checked the app and with the 12 hour format it dissapears, but I prefer the 24 hour format and just need the time. Thanks in advance
Hey @Isaac_Schloss
I’ve have tried this too and have found no way of removing the sun/moon indicator.
The wakey usually set up with 24 hour format and it’s include the sun and moon icon display. If you want to remove the sun and moon icon, you have to change it with 12 hour format. That’s the only way to remove the icon.:joy:
Is it possible to add an option in a firmware update? I think it would be nice to only have the time displaying. 24h is the way to g. :slight_smile:
I have seen reviews with the Wakey in the 24 hour format and not display the sun and moon here on the forum.
I thought it would be under LED in the app, but just the brightness level. It doesn’t change to the moon symbol until after 10 p.m. I noticed.
I need to get a wakey lol
They also make a great night light!
Funny that its a great alarm clock yet i have the display turned off while i’m in bed because it produces too much light even on the lowest setting, kind of defeats the object of having one!
After living with it for a few months it basically gets used as a wireless phone charger!
I just wish it had Google integration. I have a wireless charger and Google mini on my night stand. So another item would just clutter my night stand
Needed to be smart really - standby for version 2!
Maybe called “Wakey Again” :grin:
Yea a smarter wakey would be a great item!
Can you find that review? Cos this is what our support team told me.:joy:
Hey @AnkerOfficial here’s a couple;
Although i will add the clock display doesn’t look right in some of the pics - off centre and LED dots missing which looks quite poor and a bad representation.
I tagged you in one (review by Rayker Terrero) July of 2019
