I recently bought and received the Space A40 buds, but when I try to use voice assistant it uses bixby (I have a Samsung). is it possible to change a setting anywhere to use google assistant instead? thanks in advance.
Soundcore Voice Assistant
Hi - I had the same issue.
I went into Setting > Apps > Bixby Voice, then selected “Disable” at the bottom of the screen
I had to do this step even if Google Assistant was my default Virtual Assistant. My headphone controls now automatically select the Google Virtual Assistant
