Soundcore spirit x won't turn on
My sound core spirit x after 2 weeks of use is not turning on. I tried to reset and isn’t also working
@professor, hope you don’t mind.
In this case, please contact service@soundcore.com.
-Try a different wall charger and cable to charge the earbuds at least 24 hours no matter the indicator is on or off
  • Make sure the wall charger and cable used can work properly before testing it
