Soundcore Spirit X not charging
Hi
I bought my Soundcore Spirit X in June 2020
It has stopped charging.
I have tried 2 cables and 2 blocks and for 24 hrs
(Blue light) Doesnt come on, when plugged in there is flickering red light
Any advice?
Should i send back?
Thanks
James
James you could take a look if there is some “debris” in the socket.
And you should contact the soundcore support.
Hi Chiquinho
Thanks for your message.
I checked port and no debris.
I tied a third lead and way of charging.
Still not working just red flickering light
I have also contacted Soundcore but no response yet…
Thanks
James
If they are under warranty, soundcore will find a solution, I am sure about.
Good luck James.
Franz
PS : An answer will take a while, be patient.
