Hi, My Soundcore Spirit Sports Earphones now have rapidly flashing red light while charging, will not charge or power on, any ideas?
Soundcore Spirit Sports Earphones - flashing red light while charging
Flashing red means low battery. It is possible the battery can no longer hold a charge or is having some other issue. How long have you had the headphones?
had them for about 10 months
What did you charge then with? It can be, if you don’t have proper trickle charge then you’ve been over charging them.
Email… support@anker.com
Include, where n when you ordered, order number, serial number of the item (it’s on the little tag on the headphones).
State what’s wrong and if you’ve tried different cable n charger.
Hey, did this issue get resolved and if so how? I’m dealing with the exact same thing and it’s very annoying
